Graphics error when printing!
5 ANTWORTEN 5
Nachricht 1 von 6
drenL5229
390 Aufrufe, 5 Antworten
Hi all,
It is really weird, I have this glass elevator and some steel columns which for some reason won't print the same even though they are identical and they show as gray in the Revit environment.
Please see below the attached pic. As you can see the left column is printing white and the right one is printing gray. They both show gray in Revit!
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: drenL5229
Shadows or Depth Cueing?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
drenL5229
als Antwort auf: L.Maas
@L.Maas ,
Can you please elaborate more?
Nachricht 4 von 6
L.Maas
Have you activated shadows or depth cueing activated in your view
Louis
Nachricht 5 von 6
drenL5229
@L.Maas ,
Non of them are enabled, unfortunately!
Nachricht 6 von 6
L.Maas
Phasing or filters applied?
What happends if you create a new view of that area, same issue?
Otherwise consider uploading (part of) your project with thtat particular view.
Louis
