Graphics error when exporting elevations to DWF with Realistic setting
2 ANTWORTEN 2
Nachricht 1 von 3
515 Aufrufe, 2 Antworten
We are having an error when exporting elevations to .DWF  and .PDF files. There are areas where the image is not rendering. Instead, areas of the elevation are shown as "white boxes." We have played around with the plot/export settings (e.g. setting low resolution for export, switching between vector and raster processing), but there does not seem to be a consistent solution for this problem. It appears to be fairly random.
We are an interior design firm and export elevations in realistic mode to show clients accurate finishes. We commonly send .DWF and .PDF files. This rendering error appears to be a hardware/software issue. Has anyone else experienced this? I can take it up with AutoDesk, but I just through I'd post here first to see if anyone has had a similar issue and/or possible solution. Thanks.
Examples are shown in the attached image files.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
If it happen when you batch export a big number of sheets, then try just a few sheets at a time, or even a single sheet, and see if the problem still occurs.
Nachricht 3 von 3
als Antwort auf: ToanDN
Thanks for the reply. I've troubleshooted this problem, and it occurs even when printing a single sheet.
