i created our new logo for our title block using a fill pattern. i made this logo a generic family and inserted it into the title block family. when i print either from the title block family or the project the title block is in the curve in the logo seems segmented. when i print the logo from the logo family file it appears okay. i am including PDF's of both conditions.
Gelöst! Gehe zur Lösung
Gelöst von Ilic.Andrej. Gehe zur Lösung
We have our logo as a .png in the title block family. That might be easier if you have a good quality image?
Create the filled region with the <Invisible Lines> border. It will be still segmented but less annoying.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
we had an image as a logo. we couldn't get the resolution high enough. we would create a PDF of a sheet and the logo would not print crisp. once we inserted the logo it would always come in at 72dpi.
I'm with @Ilic.Andrej on this.
Create the logo with the solid hatch in AutoCAD. Import it in generic annotation family, do not explode, and load it your titleblock.
