Graphic show
ahmadfiroozi000
Graphic show
ahmadfiroozi000
Hi
ennujozlagam
try this delete your current view and create a new one. set your detail level to FINE, updates you graphics card driver to the latest. if still not fix the issue try to switch off your hardware acceleration from options and see if helps. thanks
ahmadfiroozi000
It is a huge project I can't delete non of the parts
The graphic card is updated and it is fine view
ennujozlagam
what do you mean? i only ask you to delete your current 3D view and create a new one, if you don't understand? thanks
TripleM-Dev.net
Any dwg links/import visible in view, try turning them off in the view?
Sometimes that's enough to restore the view, else no other option to re-created the view as @ennujozlagam suggests.
- Michel
XXalessio.amodioXX
@ennujozlagam gave you the correct soluition.
He ment to delete the current 3D view where this issue happens and create a new one.
Nothing related with the project itself.
This is a simple bug
