Graphic overrides / phase filters of linked models
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
Sahay_R
1597 Aufrufe, 14 Antworten
Hello all
i have been tasked to create a set of colored overlays for a remodeling project. My workflow - create a blank project, link the shell and fit out models, and then apply graphic overrides for New and Demolished. The Demolished override works perfectly. New does not. Any ideas at art? I really don’t want to copy and paste elements from the files.
regards
Rina
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: Sahay_R
Check Phase mapping of the links and make sure they match the host's.
Nachricht 3 von 15
Sahay_R
Already checked. Phase filters have identical names. Demolished and Existing are perfectly overridden. New is not.
Rina Sahay
Nachricht 4 von 15
hmunsell
what are you filter settings? can you share a screen shot?
Howard Munsell
Nachricht 5 von 15
Without digging in to deep, you can create views in the linked models as you like and set the links the host model views to Display by Linked view.
Nachricht 6 von 15
Sahay_R
Rina Sahay
Nachricht 7 von 15
Sahay_R
@ToanDN @I can’t create views in the linked models - the client wants to see Demo in red and New in green. I can’t do that in the linked file without messing up a whole bunch of things
Rina Sahay
Nachricht 8 von 15
Sahay_R
Is it just my imagination or we can’t edit Show All?
Rina Sahay
Nachricht 9 von 15
No you cannot edit Show All and it is a good thing.
Anyhow, can you show the Phase Mapping of one of the links?
Nachricht 10 von 15
Sahay_R
Rina Sahay
Nachricht 11 von 15
hmunsell
it worked for me.... exterior walls are existing, Interior walls and kitchen is New and the counter in the top left is demo.  Update... My Bad.... I'm not using a link in this example. when i try it with a link i get the same results as you. the link is not taking the phase settings.
Howard Munsell
Nachricht 12 von 15
Sahay_R
@hmunsell I’m having a feeling it’s something to do with my file. Did this work on a linked model?
Workaround - I linked the shell into the cutout ( the fit out has more info in it) and applied the filters. Walls from the shell still didn’t show up as green, but most of the info is correct.
Rina Sahay
Nachricht 13 von 15
syman2000
Did you set your phase filter to Show Complete? I look at your phase filter setup. Show complete set as override for new, existing and demo. Normally I wouldn't change the default setting and instead create a separate name. Reason is if you use link by view, it will set to the link phase filter. This means you have to go into the link and check to see if the phase filter is the same as your current model.
Nachricht 14 von 15
Works fine here.
Nachricht 15 von 15
Sahay_R
als Antwort auf: ToanDN
Phantasmagorical as always, @ToanDN ! Much obliged.
Rina Sahay
