Hey everyone,
I am trying to achieve the following graphic through graphic overrides in Phases:
yellow: torn down
red: newly built
black: existing condtruction
the problem I encounter is that I can override the colors but I can't s keep the existing section pattern. The result looks as follows:
Is it possible to achieve the first graphic through the diplay of different phases?
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
Just clear the pattern overrides and only adjust the colors as you want them.
Clear phase pattern override
Thank you for the quick answer! I had done that before but still had a material in the materialsection which overrode the display, after deleting that I have got exactly the results I needed.
