Graphic display show uncorrect
Dear All
I use Dell Precision M6800 AMD Firepro display card. I working on Revit 2014 when i change view to 3D view the graphic card it look like error display but when i sroll mouse this display is will back to normal. Anyone know how to fix this? Thank you so much for your suggest.
L.Maas
A graphics issue. This might be caused by many things. There are different things you can try to see if it improves.
Most Common Solutions:
-Look at the settings in Revit. Try different selections to see if it solves your problem (notably deselect hardware acceleration).
-Install the latest Revit Updates.
-Update the drivers for your graphics card.
-Install updates for your operating system.
Note: Sometimes it might be required to restart Revit or restart computer to have an effect
Louis
Please mention Revit version, especially when uploading Revit files.
