GPU
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
KIMHENGHOR98
347 Aufrufe, 3 Antworten
GPU
Does Revit work well without GPU.
3 ANTWORTEN 3
Nachricht 2 von 4
jay_colcombe
als Antwort auf: KIMHENGHOR98
Short answer is YES
If you are planning to get into larger projects or high LOD then it does seem to improve responsiveness working in complex views but overall its very negligible and even then you'd be better off bumping up the CPU then adding a GPU.
Rendering in Revit only uses CPU. However, if you are working in 3d view or using shade or other graphic options, GPU will be needed to smooth the 3d browsing. Otherwise, the gaming GPU with 2GB will be enough for any simple work.
This link is very useful
https://www.cgdirector.com/best-pc-for-autodesk-revit/#:~:text=Even%20though%20Autodesk%20has%20made...!
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 4
ennujozlagam
https://www.quadmeta.com/blog/how-to-choose-the-best-computer-for-revit-hardware
Nachricht 4 von 4
why are you buying a computer without a GPU?
