I have a file that seems to work normally but,,,, I try to add a slope and it says there is a issue with the lower and upper limit settings. Understand all that but the error message says change or delete. I try to delete and it says can not be deleted while editing. However, where ever I look I can not find a ramp being edited. It allows me to edit existing, just can not put in a new one. Anyone with a thought?
Go to an elevation and add a temporary Level above the very top Level. Go to the top Level and add a Ramp there. It should do it. When done, delete the ramp and the temporary Level. Now, you can create a Ramp without that error.
Is it possible that you do not have a level above the ramp; no "Top Constraint" to calculate to?
