Hi friends
I have to design a building on a hilly site. So, i need to create a model in Revit of this hill topography showing contours and site features such as trees.
I have explored this forum and you tube to find a way to import it from Google Earth in to Revit. I came across so many ways of doing it and so many things like using flux with dynamo, sketch up, import in AutoCad, .csv file and so on that i am confused about what way i should adopt.
What is the recommended way to create it ?
Solved by RDAOU. Go to Solution.
Solved by rudi.roux. Go to Solution.
I would ideally export the model in Infraworks 360 http://www.autodesk.com/education/free-software/infraworks-360
Hello @sakar_deepak
I think it is up to you to pick and choose based on your knowledge with those software. You are not going to learn Dynamo or download and start using sketch up just to transfer a Google Earth to Topo?
Personally I am not the guy who works on topo surfaces usually we get them from Civil 3D ... but I have assisted some of my coworkers to do it using Dynamo...However, there is this cool App for Revit which might help you do what is needed. Check it out on Autodesk App store
https://apps.autodesk.com/RVT/en/Detail/Index?id=4910606560103189779&appLang=en&os=Win32_64
Hi @sakar_deepak,
Hope you are well!
CADtoEarth is or has been the preferred choice for a while among users to achieve what you are looking for, also mentioned by @RDAOU.
THIS POST served as a solution for another community member. (3x useful links included).
Then, regarding topo surfaces, here is another BRIEF POST which served as a solution which might of future use to you.
I hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
As what I understand you wanted to create the actual topography of the site where your building will sit on. I don't think you can create the topography from just google earth or can create it accurately from google earth. The way we model a topography from an existing site, we would get the survey points first from the surveyor and then plot those points in revit as a topography element.
Dear @rudi.roux and @RDAOU
I imported surface in revit from 'Cad to earth' ; but it inserts just a flat surface with no thickness !! No mass !!
What is wrong ? ( Just for your information, Google Earth has stopped working since 11th January 2017. Now Cesium is to be used. )
Dear @Anonymous you are right. But let us see how this app works. It is good if it is reasonably accurate.
Regards
Hey @sakar_deepak
example:
If in Canada http://geogratis.gc.ca/site/eng/extraction
If in the States https://viewer.nationalmap.gov/basic/
6. and some University sites (requires that one is a student in that university to use services)
7. there are also paid service example Digimaps http://digimap.edina.ac.uk/digimap/home ... and this is how it works Digimap12.pdf
Appologies but I will step back on this post - Too many cooks spoil the dish 🙂 so best of luck
Dear @Anonymous
Thanks for the reply. I know this way of doing. Ultimately one will have to do the same.
Here i am exploring how to extract the same from Google. If you google you will find many videos showing you doing the same thing.
Following is one link for your perusal.
https://www.youtube.com/watch?v=FrIZGcPvSDY
Dear @RDAOU
Appologies for not making my point clear.
This link will show what i want. I want this with contour lines.
Google Earth is not working in the 'Cad to Earth' pane window. Though Google Earth is working if you run Google Earth dieerctly in independent window.
If Google Earth is not working with 'Cad to earth' app , does that mean this app is not useful any more for any purpose ?
Dear @sureshchotrani , Do you have a video explaining how it is done in Infraworks ?
Hi @sakar_deepak,
HERE IS A VIDEO which you might find useful. (Topography from Infraworks to Revit using Rhino & Excel).
Hope this helps!
Rudi Roux
LinkedIn
I believe it works similar to Google Sketchup...Haven't used it before. Im not sure if but I think it produces can produce a point cloud which you may be able to import to AutoCAD C3D...more or less similar to the workflow in Infraworks
Did you try if google sketchup still works or you don't have it?
I ve just tried it and it is works ... will post the screencast once it is uploaded
Screencast below...
