We are working in Google Drive when saving .rvts', it works fine but sometimes when i work from another PC the main file doesn't sync but the backup-files do.
This has results in many hours lost due to sync-fails (which is pretty f**kn, annoying).
Anyone else experiencing the same, any tips, solutions, please help!
I think you should not use Cloud service such as Google Drive for worksharing.
The tips from the article:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Google Drive is not supported for hosting workshared Revit projects. Yes, I have seen the "hack" out there that does say it works, but refer to the other post on this thread about services that are supported.
It's just wierd how it works good, except from when I swap PC:s... I'm the only one in our team that has this issue and also the only one swapping PC:s.
