Hello all,
I use the Revit 2018.2.
In my autodesk account I cannot find the 'Globe link' subscription add-in.
Is there something that I need to do?
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hello @mairh_tsek,
I am not sure about what product this is, I do see a DB Link add-in for Revit 2018.
I will move this post to the Revit forum for you, this is a product related issue and a product specialist could better assist you with these types of questions.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hi @natasha.l
Thanks for helping out. ![]()
Globe link is a subscription add-in that was available in older versions and not for RevitLT, but I'll have to confirm this with the product managers.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @mairh_tsek
I just heard back from the team, and here's an update:
Currently the 'globe-link add in' is discontinued and not available in Revit 2018, last available in Revit 2014.
I see that on your other post, we've discussed the 'cad- to earth' and you seem to have issues with that. since that app is not an Autodesk product, I would suggest that you contact their support (amcbridge) Also see their help document.
If you can tell us more about your workflow and what you are trying to achieve we can discuss more about available export formats and workarounds.
For example: If you are looking to export an image from google maps we can save the image and use it as a background in Revit.
I look forward to hearing from you.
Viveka CD
Thank you for your answer.
I want to place my model in a 3d google environment. I want to be able to see the others building in 3d too.
Check the image.
Using the Cesium in CADtoEarth I take a 2D google environment.
Is it possible with the Revit 2018?
Hi @mairh_tsek
Thank you for your response and what you have tried so far.
I got your messages.
Let me get back to you. I've opened this topic to the team for workarounds and further feedback.
Viveka CD
Hi @mairh_tsek
The best workaround would be to use the background image and trace/model in Revit - this gives you the option of making it parametric.
Viveka CD
I think the new Autodesk Infrawoks is supposed to do this. I haven't had the chance to try it out for myself, but if it is as advertised, this is exactly what it is supposed to do. I believe you do need a 3rd party mapping software to acquire the surface, but all together should do the trick. I look forward to hearing if anyone has had the opportunity to try it out with a Revit model.
Hi @mairh_tsek
You can try a workflow using Navisworks.
Ugur Kaya
Thank you for your answer!
This is what I a trying to do the last days but when I fill the values in the pop up menu the model displays in a completely wrong position.
Check the thread below:
https://forums.autodesk.com/t5/navisworks-forum/navisworks-kml-options/m-p/8441605#M18734
If you have a guideline it will be appreciated!
Hello @mairh_tsek,
In my case, which is located in Turkey, I tried to convert my coordinate system to "GRS 80" system. At the next step, I change degree, minutes, seconds to longtitude and latitude. As I saw at your post, you are converting to "WGS84". Hope this converting method will help you.
und auch in Revit 2020 nicht und auch nicht wirklich ein gangbare Weg.
Also WIE IMMER mit Autodesk
Es gibt was tolles Neues
UPS es wird schwierig
nun ja wir schaun mal
und ne das ist nix braucht niemand .. Hauptsache Show
cu cw
Good afternoon, any updates please? so it's completely impossible to publish my model into Google Earth?
