Globally change sheet border info across all sheets?
3 ANTWORTEN 3
Nachricht 1 von 4
payingtoomuch
258 Aufrufe, 3 Antworten
Have various "switches" for a sheet border that is used across the entire project that I would like to select one time and have the setting changed on all sheets. Is this possible?
An example would be a "Not for Construction" Stamp.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: payingtoomuch
You mean something like this?
Text-type Shared Parameter Label on Titleblock reports the value of the exact same Shared Parameter assigned to Project Information via Project Parameters.
Nachricht 3 von 4
handjonathan
Hi @payingtoomuch
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 4
Tom_Kunsman
Try selecting the titleblock, then right click to select all instances in Project, then from properties change the Instance type. Typically, a "Not for Construction" stamp is better as a Type property and not instance.
