Global Parameters in Model Groups
7 ANTWORTEN 7
Nachricht 1 von 8
836 Aufrufe, 7 Antworten
Hi all, I have a model group with a global parameter that controls the height between SSL-SSL upper floor.
This parameter controlling height changes depending on the level the model group is placed.
I would like to use one model group but change the parameter for each case, how can I manage global parameters in model groups once they have been loaded in a model?
Help more than appreciated.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
You mean you want Group Instances to change?  That would defeat the whole purpose of Groups.   Groups are copies.
Nachricht 3 von 8
Make a family so you can control the height. Use a two-level family template for automatic level-to-level height control.
Nachricht 4 von 8
als Antwort auf: ToanDN
@ToanDN @barthbradley
I already created a model group of the apartment.
Could we do this with the model group?
Nachricht 5 von 8
see attached. Why we couldn't add a type parameter here?
Nachricht 6 von 8
No, you cannot.  Model Groups are static.  You could try an in-place family to add a height control instance parameter.  Since no one has mentioned it, you cannot use a Global parameter to control different heights.  You must have one global parameter for each height.
Nachricht 7 von 8
Toan you mean an in place family into a model group?
Nachricht 8 von 8
joe_keogh
Instance Global Parameters of of the following types can vary between instances of Groups:
  • Text
  • Area
  • Volume
  • Currency
  • Mass Density
  • URL
  • Material
  • <Family Type>
Length Parameter type cannot change between instances of Groups.
Please reefer to this link
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
