i have been facing this issue for some time now in almost every revit file i create. when i go to 3d, all the invisible lines (slabs, walls thickness, furniture inside) and when i want to align to a face the faces do not highlight. i will attach a screenshot of the issue
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Check your eye & target elevation. It will display huge value. Simply use the view cube and click on the isometric. This will reset your view back to normal.
