Glazing system is existing (or demo phase) but panels are in current phase. How can I change all to existing (demo)?
2 ANTWORTEN 2
Nachricht 1 von 3
vydang484TA
184 Aufrufe, 2 Antworten
Hi All,
I'm having a problem with the glazing system, that I set the glazing system to existing phase, but some of the glazing panels are still in current phase. I tried again by selecting the whole glazing system then change to existing, but still didn't work. Has anyone have the same problem before and how to fix it? Thanks a lot,
2 ANTWORTEN 2
Nachricht 2 von 3
SteveKStafford
als Antwort auf: vydang484TA
Select the curtain wall, use Cut to Clipboard and then with the correct phase active, use paste aligned > Same Place or Current View. That should reset the overall curtain wall and its sub-elements.
Steve Stafford
Nachricht 3 von 3
vydang484TA
als Antwort auf: SteveKStafford
That works perfectly. Thank you so much!
