Hi all,
We're seeing that glass is showing black in the Realistic views setting. Anyone figured out what causes this and how to fix?
I've tried swapping out the appearance asset in the material browser and oddly only some of the windows change to the required transparent light blue.
Any help would be appreciated.
Without inspecting the model it is a guessing game
Thanks for the reply.
To answer your questions:
Window Families
There are different Window Families with the same material for the glass element
None
All have the same glass material
Did you use mirror cool tint as your glass material? This would display black with realistic
If you swap it with blue glazing, it shows up as glass.
Does your Glass Material have a Reflectivity Appearance Asset? If so, uncheck "Reflectivity" and see if that corrects.
