Hi there,
I'm having a few issues with rendering a mass that is made up of a glass and mullion exterior. The issue only happens when i render in the cloud. V-ray for revit and the dedicated revit rendering (ray trace i think) don't have issues with it at all. It also takes a very long time to upload the view to the cloud.
Attached are some images.
Hi @liam_reidy
Thanks for posting on our forum. Thanks for sharing your images.
Can you specify what these issues are? Is the glass appear darker or lighter? Or is the quality of rendering is your concern?
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Well the main issue is that in the first image, the glass is black and almost mirrored. Though that only occurs when i render in the cloud. The second is the time it is taking to upload to the cloud.
Cheers.
Hi @liam_reidy
Can you share the file? We can send you a private upload link if you'd like.
Viveka CD
Hi @liam_reidy
I've shared the upload link with you.
Let me know if you have trouble accessing.
Viveka CD
How did you go about sharing the link? Can't seem to find it.
Cheers.
Hi @liam_reidy
I have shared the link to your email
Also, check HERE
Let me know if this works for you.
Viveka CD
