Glass panels/baluster - can the parameter equal the baluster spacing?
mp_thompson
mp_thompson
Can the glass panels/baluster family be amended to make the width of the glass panel/baluster equal to the baluster spacing within the railing settings?
www.thompsonarchitecture.co.uk
Hi Matthew,
I believe if you have two balusters in the family, and you space the panel out 'evenly' (using dimensions) between the two balusters, then it should auto update the length of the panel, depending on the settings in your project.
In plan view in your family, you'll most likely have to lock the two ends of your panel to the balustrades.
Cheers
