Glass Opacity
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jfjacques
1011 Aufrufe, 2 Antworten
Glass Opacity
I have an elevation looking into a glass curtain wall. There are stairs behind it. How do I make a glass wall transparent in elevation?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: jfjacques
Glass in not transparent in 2D Views. You can fake it by hiding the Glass in the View though.  Yes, I'm serious.
Material transparency in Revit 2D views | Revit Products | Autodesk Knowledge Network
...or make a 3D Elevation
Nachricht 3 von 3
semhustej
You can select the glass object in your view, right click, select "Override Graphics in View", "By Element" and than set surface transparency to different number than 0. 100 means the object will be fully transparent.
Tom
