Glass Material not rendering correctly
1 ANTWORT 1
Nachricht 1 von 2
lee.imbimbo86EM4
256 Aufrufe, 1 Antwort
I'm trying to generate a stained glass window and I'm having this weird issue were the color will look great in the Material Editor and then not be that color upon running the rendering.  In particular the Blues and the Yellow are not generating anywhere close to what I see in the Material Editor.  I've attached some pictures and the family to see if anyone else has any better luck.  This is for the front door on a residential development so I wanted it to look good in the rendering.  but I just can't seem to get the yellow and blue's to pop.  The green, red, purple, and two different textured clear glazing seems to be working well.  but the two blues and yellow see to just stay muted.
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: lee.imbimbo86EM4
Rendering is always set by the eye of the beholder. As well light affects rendering look of the glass. I use Enscape and the glass render differently from your screenshot. I would try adding more light and see if that change the glass color.
