Giving different material to split floors
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
adiA48P7
1553 Aufrufe, 5 Antworten
I am trying to update the materials to some of the floors but I can't.
I splat the floors but they still work as one element.
Since it is a huge project i don't want to redo the floors, just divide and change to some of them their materiality.
Thank you
Adi
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: adiA48P7
Use split face and paint each floor area with a different aerial. Or create parts from the floor, divide parts and override parts materials.
Nachricht 3 von 6
emodderman
I know you said you don't want to redo the floors, but if you copy and paste a floor into the same place, and then edit the boundary of each floor, you can remove what you don't need from both floor footprints, leaving you with two separate floors without 'redoing' the floors. then you could switch one to a different floor type...
Parts are great, but they add complexity that sometimes isn't warranted.
OR, you could also take the main floor type and remove the finish from the floor. keep just the main structure element and subfloor, if it will be consistent over the whole plan. Then, you just edit smaller finish floor elements in specific areas. it's still more work than having one big floor, but splitting and painting, or making parts is also work, so it depends on your speed at these different types of work.
Nachricht 4 von 6
mhiserZFHXS
I'm thinking the issue here is that you are changing Type properties of the floor, and therefore changing all floors of that type. If that's the case, you need to duplicate the type and then change its properties.
Nachricht 5 von 6
adiA48P7
als Antwort auf: ToanDN
thank you!
Nachricht 6 von 6
adiA48P7
als Antwort auf: mhiserZFHXS
thank you
