Ghost view filters in Revit LT
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
jesseM225G
410 Aufrufe, 3 Antworten
I have been trying to work out why I can't see certain elements in floor plan views in Revit LT, and have concluded that the problem is being caused by a view filter that was created in our template in the full version of Revit.  You can't create view filters in Revit LT, but it seems you also can't turn them off if they've been applied in the model by someone using the full version of Revit.
Worse than that, it is impossible to even discover if a view filter is active in a view.  It will be having an effect on the drawing but it seems there is no way to discern if it is active or not.  I have only been able to work this out through the famous 33 step process of element visibility deduction, which is of course a massive inefficiency.
Does anyone know how to turn off view filters in Revit LT and will this omission be fixed in a subsequent release?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: jesseM225G
Create new working views from scratch and everything should show.
Nachricht 3 von 4
jesseM225G
Thanks ToanDN, that seems to reset the situation successfully.  Do you know if there is a way to determine whether there is a view filter active in RevitLT?
Nachricht 4 von 4
By comparing the view in question (after revealing all hidden elements) with a freshly new view, I guess.  Place them side by side on a sheet.
