Ghost lines from linked STR model
vghozlan
Message 1 of 14
vghozlan
I'm dealing with some weird ghost lines from the first STR model we linked to our file. They show/disappear depending on the angle/zoom, and having them outside the section box doesn't prevent them from appearing.
We received a new STR model, I removed the previous one and uploaded the new one and still has these lines. I'm not able to select them either, seems like a visual artifact. Abny lead on what that may be and how to remove it?
Replies (13)
Message 2 of 14
RDAOU
@vghozlan
Could be cause by various reasons and with the info you shared it is not easy to tell which. With nothing in hand to check, the following are the most common causes I can remember
  • Could be graphics performance issues (disabling Hardware Acceleration in options might help)
  • Could be a partially exploded Import...try linking instead
  • If it is a DWG link, try link it into an inplace Genric model
  • Could be a large linked model which has parts of it falling outside Revits drawing limits and that causes such graphical inaccuracies (setting linked model to display By Link and using a section Box therein to Cut the 3D view used might help)
  • Could be corrupt file or view. Try to recreate view or audit the file
Message 3 of 14
vghozlan
Thx Rdaou,
I've tried disabling hardware acceleration before making this post, didn't help.
File is linked, not imported.
It's a Revit model, linked.
I'll try that section box from the link file, that's worth a try!
Message 4 of 14
Do they show if you set the link display to By Linked View and choose a 3D view from the link?
Message 5 of 14
vghozlan
Hi ToanDN,
Yes, I've set a view on the linked file to try that section box into the linked file lead, and set the Revit link display by Linked view from that file and the ghost lines are still around.
Noting that they are not showing on the linked file itself. The ghost lines are gone if I disable the Revit link from my main file's 3D view.
Message 6 of 14
RDAOU
@vghozlan
Can you open the link and enable the Internal Origin visibility then check how far it is from what has been modeled there in?
And while at it, maybe you could also check for any GPU drivers updates.
(PS: I am ruling out the possibility that you are using MAC, running a virtual maching and/or using an onboard intigrated GPU)
Message 7 of 14
vghozlan
Hi Rdaou,
I'm using R22.1.50.17 on windows 10 pro.
The project base point, Internal origin and survey point are all within the project's boundaries.
I've run a GPU update, but unfortunately, that didn't sort out the problem.
Message 8 of 14
RDAOU
@vghozlan wrote:
Hi Rdaou,
The Revit build you are using is out of date the current is 22.1.80.32 Could you maybe download and install that first?
Message 9 of 14
vghozlan
Installed the hotfix, no change. Not sure where these artefacts are coming from, but since they don't appear on issued drawings I guess I'll just have to ignore them.
Message 10 of 14
RDAOU
@vghozlan
If you recreate the view or if you Link it into a clean model...do you see the same artifacts there? It might be a corrupted view.
Message 11 of 14
vghozlan
I created a new 3D view, artifacts are still displaying. I linked the STR model into a new file, no artifact.
Message 12 of 14
RDAOU
@vghozlan
Did you audit the file as previously suggested?
  • remove the link and relink new into the model
  • if it is a workshared model (cloud based)…close Revit >> clear collaboration cash >> reopen
  • if it is workshared on a local or remote server; rename the current local and create a new one
Message 13 of 14
vghozlan
@RDAOU
The linked file is a detached Revit project. I have already tried to re-link a save-as version of it under a different name.
Message 14 of 14
RDAOU
Not the STR model… the host model where u r linking the STR into. If that is workshared, clear the cash and/or recreate local
