i have 3 models linked into a main file i need to create a GFA computation each block and one combine GFA of 3 blocks but i dont know how to start. i also make a room schedule and tick the linked files but don't know where to start. bytheway each block has it's own GFA calculations, can these possible to show in the main files? any help suggestion is much appreciated. thanks
Create area plans for these and schedule the areas. You can apply formulas to the schedule to calculate GFA if required to calculate coverage.
As @Anonymous said, Area Plans will be helpful with this. You can "customize" the placement of the Area Boundary Lines by unchecking the box in the Options Bar called "Apply Area Rules." Unchecking this box would allow you to place the Area Boundary Lines wherever you want within walls and room-bounding objects, the lines would not snap to the middle/outside of the walls like they do by default.
