Getting Skechup file to load in Revit
Effrickey
Observer Observer
Message 1 of 8
Effrickey
Observer
Observer
  • I received email with Sketchup file in it loaded in revet pro 2022. And I can't open it up to get the layers open to do renders any ideals to help  thank in advance
Replies (7)
Message 2 of 8
So you can't import the SKP in Revit or you can import but you cannot change materials?
Message 3 of 8
Effrickey
Observer
Observer
I imported the skp file into revit 2023, but I cannot change the materials. Is it one mass now? How can I change it to where I can apply materials to the surfaces for rendering?
Message 4 of 8
You can import the sketchup file in AutoCAD, save it as DWG and link the DWG in Revit so you can change materials via Object Styles (layers).  Or share the sketchup file here.
Message 5 of 8
Depends on the SKP. Open Object Styles, go to Imported Objects Tab and see what SKP Layers are there and what Materials are assigned to them.
Message 6 of 8
Effrickey
Observer
Observer
Where is the Imported Objects tab?
Message 7 of 8
Manage Tab=>Object Styles
Message 8 of 8
RyanCameron
Evolelab.io makes a plugin that takes Sketchup and directly converts it to Revit called Helix 2.0.
https://www.evolvelab.io/helix
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
