Is there somebody who can help me with making revit model redy for NS3420?
I'm struggling whit automatic building of elements in NS3420. I want to get a headpost of for example Exterior wall and then subposts for all the layers in the wall for pricing.
There may be a consulting organization in your country that has worked out a strategy. Revit is built to use Omni Class and Uniformat (parameters in content refer to Assembly Code) for each element category. If you have to reference this system that does the same thing conceptual but using it's own "numbers" and "descriptions" you'll have to create your own parameters to store these values. It might be possible to hijack the source file that Revit uses for Assembly Code parameters and substitute the values your system uses...
Steve Stafford
Thanks ![]()
ive talked to A company whos using classify for ns8360 that can generate ns3420
AS i understand they are using the assemblycode
Yeah, that was my thought since the Assembly Code data is based on a TXT file and as such it seems like it could be hacked to used different code values and descriptions.
Steve Stafford
