Getting error 'Can't make change to group [...]' for a group that doesn't exist
7 ANTWORTEN 7
Nachricht 1 von 8
editavinca
898 Aufrufe, 7 Antworten
This error appears when I try to duplicate a floor plan with option Duplicate with Detailing. The error says that the 'Beschriftung' group is the problem. It doesn't give the group's element ID (see attached error report).
I have gone through all the model groups and detail groups of the project both manually and using Dynamo, and a group with the name 'Beschriftung' simply does not exist. I have purged & audited and it still shows the same error.
When I duplicate the same floor plan using only the 'Duplicate' option, this error doesn't appear.
I think it has something to do with a conflict between Duplicate with Detailing and Attached Detail Groups. I found a previous thread on this but it was never solved.
https://forums.autodesk.com/t5/revit-api-forum/view-duplicate-withdetailing-fails-if-attached-detail...
Is this definitely a bug or am I missing something here?!
Thank you!
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: editavinca
It's possible that the group resides in a family in the model.  You can try and export the families (right click on Families in the browser) and Revit exports these to a folder that you define.  If there is an error with a family then Revit stops and asks what you would like to do.  You nay be able to determine if it is an error in the family.
Nachricht 3 von 8
indiana_j0nes
Beschriftung is german for Annotation hahahaha
Kunal Tuljaram Gaidhankar
Nachricht 4 von 8
indiana_j0nes
Is it possible to share the file so we could look into it?
Cheers, K
Nachricht 5 von 8
editavinca
als Antwort auf: indiana_j0nes
I know, I am working in Vienna. What's your point?
Nachricht 6 von 8
indiana_j0nes
I cant recreate the issue at my end.
It works flawless for me.
Nachricht 7 von 8
editavinca
als Antwort auf: Anonymous
Thank you, I think it was a good suggestion! However, while exporting all families (310 in total) only a couple of them showed warnings but none of them involved this group
Nachricht 8 von 8
editavinca
It also works for me, for the other floors. There's only one floor which shows this error... I guess it's a very specific situation. I cannot send the original file, unfortunately. Thank you for your effort though
