Get true size of roof slopes
Message 1 of 12
Is there any possibility I can see and print out the true sizes of roof slope planes? Does it have anything to do with reference planes?
Thank you in advance,
Replies (11)
Message 2 of 12
rosskirby
Could you elaborate?  I'm not sure I understand your question.
When you model the roof, and are still in sketch mode, select one of the edges and check the box for "Defines slope" in the Options Bar, and then assign a slope.  Alternatively, you could either add a slope arrow to control specific head/tail elevations or use the modify sub-elements tools to set specific elevations at various points.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 3 of 12
Ross Kirby,
 thanks for your attention. I am interested in getting the true size of the roof slope  to make a physical architectural model. Revit is very smart in creating forms and shapes, much smarter than me. I have designed a building model in Revit with quite complexed rood configuration, and I thought it would be much easier to get the layout of the roof, cut it out and make a cardboard model. For example, if I look at the top view, I get horizontal projection, if I look from front, I get frontal projection etc. And none of these reveal the true geometrical shape of the roof slope ( or side of facet). Of course, I cal calculate and draw this manually, but finished Revid model seems quite promising in providing information ( also about the geometry, because it has been calculated already)
Message 4 of 12
constantin.stroescu
If I understand you well you want to have a view that is perpendicular on your roof face..
If so ,then you can try this:
  1. in an elevation (profile view) of the roof draw a Reference Plane using Pick Lines - pick to the roof slope . Name somehow the Reference Plane
  2. in the same elvation make a Section . Use Rotate function to rotate Section Line so to be parallel to the roof slope
  3. open the new Section View . From Architecture>Set - set Work Plane to be the Reference Plane from step 1
  4. Now , in the new created Setion View you will see the roof plane at its true dimensions and you will be able to put dimensions using Aligned Dimensions
Constantin Stroescu
Message 5 of 12
dbroad
In addition to what Constantin said, this video gives an alternate process.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 12
Thank you for your help, looks like it's the correct way to do this. I only get to see if I did right when I will print out the elements and see if they fit together. Thanks again
Message 7 of 12
dbroad
Glad to help.  Thanks for the kudos guys!
Message 8 of 12
chrisplyler
You're welcome dbroad.
Message 9 of 12
robertovalentino
any chance to have the video again ?
Message 10 of 12
dbroad
Message 11 of 12
robertovalentino
@dbroad
Thank you so much!
Message 12 of 12
nawaz_khanLVJN9
Community Visitor
Community Visitor
Can you provide any videos or link regarding the same?
