Get subcategory layer when exporting (currently exports with wrong layer)
8 ANTWORTEN 8
Nachricht 1 von 9
Marcus.Isacsson
1469 Aufrufe, 8 Antworten
Hi fellas!
For some reason I don't get the subcategory layer when I export to DWG.
Does anyone have a solution for this?
In this case it's a fire rating line made as an generic model in 3D.
When I export I get the main category, generic models, as the layer in DWG (red in pic) instead of the subcategory (yellow in pic)
8 ANTWORTEN 8
Nachricht 2 von 9
Revit_Whisperer
als Antwort auf: Marcus.Isacsson
I believe this is happening because you created the linework inside of an in place generic model family...because of that it is considered a generic model block so to speak...inside of Autocad if you explode the generic model family it will show as being on the modified layer.
Nachricht 3 von 9
Marcus.Isacsson
als Antwort auf: Revit_Whisperer
Hi, thanks for helping out. I just tried exploding it, still same main category layer.
Nachricht 4 von 9
Revit_Whisperer
How were these elements created?
I attached a file that I exported for testing where I created a generic model, that was just lines, exported with the custom setting for the sub category and the result in Autocad is as I described.
Nachricht 5 von 9
Marcus.Isacsson
Nice, I'll check it out. Here's our family that doesn't export as intended for me.
Nachricht 6 von 9
alaafarhat
Hello guys, well i have family that is under communication category ( Electrical) but under that category we have subcategories,
Whenever i export it to Autocad the result is having the same layer and color of the category as if i didn't precise the result in the export setup (yet i did so) any urgent help would be much appreciated
Thank you
Nachricht 7 von 9
Revit_Whisperer
I was able to get the family you posted to export and when exploded it changed to the custom layer...I did a quick video
https://www.screencast.com/t/SS6E3PC0DL
Nachricht 8 von 9
Marcus.Isacsson
Alright, but you do have to explode it manually for each export? Any option or plugin that makes the exports auto explode?
Or,...maybe I need to create some old fashioned scripts for AutoCAD for that?...
This can be very time consuming (30 exports weekly).
Nachricht 9 von 9
alaafarhat
Thank you for the reply , yet i am not able to open the link some Adobe problems ,
can you please upload it to a different link or how can i check it out in a different way,
