A picture is worth a thousand words so please refer to the pictures. The first picture shows how the model looks when I'm not zooming in/out. You can see a lot of ugly black lines. The other one shows how it looks when I am zooming in/out. I like the second look better. How can I make the model look like that at all times?
Thanks in advance for your help!
Best,
Sebastian
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Not necessarily ... You type GD as mentioned above
@sebastian.gomezBVK34 wrote:
Thank you!!! Please note that to find these options, the user has to click on the "Visual Style" icon at the bottom panel. Then "Graphic Display Options"
You can use a keyboard shortcut or view's properties button to get there.
