Get individual beam cost and total type type cost in schedule
1 ANTWORT 1
Nachricht 1 von 2
645 Aufrufe, 1 Antwort
Not sure this is possible, seems like it should be. I want the schedule as I have it to report indiv beam cost as well as the total cost per beam. Currently the 'indiv' beam cost is a formulated parameter that  uses the formula Length * Cost / 1' but it seems to be multiplying the cost by the total length of the type in the whole project. Dividing by count isnt possible as 'count' is not an option to select to put in the formula. I want the indiv cost to report the price for one. Then I want to make another column which is total cost which takes indiv cost x count. Why isnt count selectable? Quite a cumbersome problem I know... reference for forum 2.JPGreference for forum.JPG
Tags (3)
1 ANTWORT 1
Nachricht 2 von 2
bin
als Antwort auf: Anonymous
Create 2 calculated parameters using the same foluma that you use. Under Formatting, set one of them to No calculation for the single price, and the other one Calculate totals, so it will equal the single price * count.
