Plenty of times when creating a Roof by Face or Wall by Face elements, there's an error (ex. 'can't create roof') without any guidance of what went wrong.
Testing plenty of examples of success and failure I wasn't able to figure what Revit wants.
Having an explanation would help make workflows more stable instead of hitting a dead end after long hours of work.
Thanks in advance,
Daria
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
you have to take in consideration when you choose to make Wall by Face or Roof by Face , the following:
So , Wall by Face has more chances to work...
Constantin Stroescu
thanks for a prompt response.
- is there a check that I can perform to test if the surface is 'horizontal enough' for a roof?
Revit doesn't let me even select the roofs that are 'too vertical', I'm guessing the selection filter is based on some calculation.
- these two shapes are based on the same geometry but coming from different sources (left is Rhino Inside Direct Shape, right is a revit family built manually). Why would one work and the other one - not?
upd. sorry, realized the second part of the question is too vague, will come back with more details.
