Geometry jumping/bugging when syncing from Revit
0 ANTWORTEN 0
Nachricht 1 von 1
marcus_barnes-batty
123 Aufrufe, 0 Antworten
Hi all!
Our team has recently switched to Revit 2025 which has the build in Datasmith sync to Twinmotion. Before we were using Revit 2023 with the Datasmith plugin with 0 issues. Since changing to 2025.3, we have noticed that on-going projects, when sync’d can change or modify the location of the geometry in twinmotion. So if an update is done in Revit, such as ceiling treatment, maybe new cabinetry etc - some objects within the scene jump in twinmotion and have to be manually moved back into place and I can not figure out why.
Also texture are removed off object that were not changed and it’s unclear as to why this is happening.
Does anyone know if the plugin is bugged in Revit or in early development? Or is this an issue with twinmotion?
0 ANTWORTEN 0
