geometry display differently in project after checked shared parameter
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
aoziang
288 Aufrufe, 5 Antworten
Hi Guys,
I created a steel box as a framing family. I inserted some structural column and framing element in that family.
There isn't any problem at this stage when I try to load it into a project. however, in order to be able to schedule the steel members, I have to check the shared parameter for the HSS columns and framing I used in the family. Things became weird from this point after I re-load it into the project, the frame family shows total wrong(feels like the work of some deconstruct artist)
Even weirder is the length data I get from the schedule is neither the ones showed in the project environment or in the family editor environment.
I tried to constrain the end point of column and framing to ref plane in family editor, but still no help.
Does anyone have any insight on this problem?
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: aoziang
What is the reason that you create a steel box as framing family?
Can you upload your family so we can have a look what you have ?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
Are you saying nested structural framing components don't flex in the project?  This is typical behavior.  The nested components are reverting back to their family default length.  There are a couple of workarounds I can suggest if this is what you are talking about.
...here, I found this workaround for columns. It can be applied to structural framing as well.
https://www.youtube.com/watch?v=pmWiQB-bZd8
Nachricht 4 von 6
aoziang
als Antwort auf: L.Maas
Hi L.Maas
It didn't need to be in structural framing family. I created it with the generic model template in the first place, however since we want to have a bunch of this steel box in the project, I feel that structural framing better describe its material property.
Please take a look at the attachment.
Thank you.
Nachricht 5 von 6
aoziang
als Antwort auf: barthbradley
Thank you!
I think that is exactly what happened in my case. I'll do some experiment and see how it works.
Nachricht 6 von 6
I just looked at your family and I'm wondering why you just don't build the "steel box" in the Project and create a Group from it.   I mean, the Host family contains no parameters whatsoever.  There's really no need for it that I can see. It's not only problematic, but you're also losing intelligence doing it this way.
That's my to cents worth.   Good luck.
