Geodesic Wall Massing
14 ANTWORTEN 14
Nachricht 1 von 15
785 Aufrufe, 14 Antworten
I have been trying to make a geodesic house but am currently having trouble getting the exterior walls to join together. I created all the walls from a mass I made of an icosahedron. If anybody knows how I could fix this issue please let me know. I have included an image of the issue.
14 ANTWORTEN 14
Nachricht 2 von 15
Ilic.Andrej
als Antwort auf: Anonymous
Select the wall and tap the space bar. Also, check their location lines....
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 15
als Antwort auf: Ilic.Andrej
I don't know what you mean, I selected both walls I wanted to join and hit space.
I'll just attach the file so you can see what I mean if you want.
Nachricht 4 von 15
Ilic.Andrej
oh, its in the file, ok....
Andrej Ilić
MSc Arch
Nachricht 5 von 15
Sahay_R
Select one of the walls and hit space. That will adjust the location of the wall. THEN try to join it.
Yeah, I couldn't see the mass either.
Rina Sahay
Revit Architecture Certified Professional
Nachricht 6 von 15
als Antwort auf: Sahay_R
I don't want the walls moved though, I am trying to have them based on the mass I created. I will add the mass file here too if it isn't loading in the project
Nachricht 7 von 15
Ilic.Andrej
I don't know why your walls are not being joined, but for these kind of shapes we usually use Curtain System. Here, you have much cleaner result.
Ofc, you can create curtain panels to your liking.
Btw, Rsahay, his mass is stored in the project browser/ families.... I've found it there....
Andrej Ilić
MSc Arch
Nachricht 8 von 15
Sahay_R
Try using a thinner wall
When applying the walls to the faces - set Location line. If it doesn't look right, you can always select all the walls and change Location Line in the properties. Wall centerline worked best for me.
Rina Sahay
Nachricht 9 von 15
The curtain panel did work but only for one face.
Nachricht 10 von 15
Sahay_R
Click face then Create System. Then you click another face and then Create System.
Rina Sahay
Nachricht 11 von 15
Ilic.Andrej
Did you look at the attached file?
Btw, when creating Curtain System, click on "Select Multiple"
Andrej Ilić
MSc Arch
Nachricht 12 von 15
Try this.
Nachricht 13 von 15
Sahay_R
als Antwort auf: ToanDN
@ToanDN idiot-proof directions, please - you got it a lot closer than I did. And what is the purpose of the little void extrusion families?
Rina Sahay
Nachricht 14 von 15
Okay.  Below is the breakdown:
I realized OP use a single face adaptive generic family to form the surface.  The problem with this is the walls by face don't always orient to the right direction so their location line may need to be change from Exterior to Interior where it occurs.  For compound walls with different finishes for Exterior and Interior it can be a problem.
I removed the adaptive family from the mass and create mass faces using adaptive points > reference lines > form.  Now all the walls by face orient consistently to one side.
There are corner cleanup glitches due to the complexity of 5 walls meeting at 1 point.  So I create a void family to trim away the remnants.
The main advantages of using walls by face here is the ability to add fenestration.  If not, using adaptive family/ curtain system/ curtain panel pattern based should give a cleaner look.
Nachricht 15 von 15
Here is another version of the mass family with two x 8-point adaptive generic family and two x 4-point adaptive family to form an enclosed dome.  The thickness can be changed by edit Type.
