Generic Model Void
Generic Model Void
almeidaandre
Generic Model Void
almeidaandre
I've created an array of model in-place generic model.
Is there a way to cut those geometry with generic model void? (there isnt a pattern void, but irregular ones).
RDAOU
Hi @almeidaandre
By only looking at an image one can only say: basically you should be able to cut those with a void geometry...however; it also depends on what you modeled and how you modeled it.
Should you be able to upload that revit file, one would be able to help you better with answering that question.
josemukalel
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
almeidaandre
Great! That's it. I think I was missing something.
And void cut them automatically, don't have to use cut command.
