i am making a lotus petal for one of my projects, i tried to follow allow the steps from YouTube but for some reason i am not able to make a void though the solid mass. it shows orange when I
make a void
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Make the surface larger so that its edges don't touch the inside border of the void and the void's ref points.
By the way, I think could make the leaf on its own without the void. Share the family here.
I just deleted yours and re-did it. I'm not sure what was wrong with yours. Didn't spend any time trying to figure it out either.
I just wanted to change the scale. I can't do it if I don't know how to make it that's the reason i asked you. but i guess i will just use your file. Thank you it is really helpful. saves me time.
Here is one without a void (2024).
Have you tried what I said to fix yours?
@sak9537 wrote:I just wanted to change the scale. I can't do it if I don't know how to make it that's the reason i asked you. but i guess i will just use your file. Thank you it is really helpful. saves me time.
Are you saying that you are not able to delete it and recreate it yourself? If you are able to, like I was, then that's the solution. Sometimes "stuff" happens.
tried it but dint work. maybe i am not doing it right. But I will try doing it again. Thank you.
Funny. Even the guy in the video is resolving issues with the void towards the end.
