Had someone help me with a project who left, and they placed a generic annotation family for ceilings. I cannot select any of their tags yet when I use the same family (which is placed using Symbol from the Annotate Ribbon I can select them. Select all in view of same type does not work. Any thoughts?
In attached image, the grey out "ETR" are the ones I cannot select, the dark "ETR" are the ones I placed. All links and imports are turned off, all worksets are visible and editable.
Gelöst! Gehe zur Lösung
Do you have a selection restriction activated. Look in the drop-down box under Modify.
...or bottom-right of UI. Maybe they are Pinned and Select Pinned Elements is turned off?
I tried with no restrictions. The grey out is what I can't figure out. It is almost like it is a dependent. But it is not part of a group, nor can I Tab to select it
