Generic Annotation tag and note block (demo Tag)
3 ANTWORTEN 3
Nachricht 1 von 4
1331 Aufrufe, 3 Antworten
I am trying to create a demolition tag, from a generic tag that I would like to show up on a noteblock.
I have done it but my problem is, I want the number in the tag to always be associated with the same description that I have when using that number.
How would I go about doing that? what is happening is, if I create a duplicate tag a new number and/or description creates.
thanks in advance.
3 ANTWORTEN 3
Nachricht 2 von 4
loboarch
als Antwort auf: Anonymous
The video on this page in the Online Help might get you pointed in the right direction of what you are trying to do. it shows using a note block for something similar to what you are describing.
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-B9CA6BD9-06F0-4E17-B7EA-201C2F81C690
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 4
Any luck figuring out how to do this?
I wanted to do the same thing for a renovation project; ended up using User Keynotes instead, which worked fine, but would have loved it if the Note Block annotation had the option to work the way you're describing!
Nachricht 4 von 4
Do you mean a Generic Annotation, because a Generic Tag is for tagging Generic models?
I have used a Generic Annotation with label for Number and a parameter for Description, both are Text instance parameters, and it works fine.  For example, I place one and enter number = 101, description = ABC, if I copy or create similar, the new one inherits the same information.  Did you get a new number and/or description if you did the same?
Anyhow, I've been moving to use Keynotes because I prefer a central database, consistency, and the ability to show only the relevant keynotes (per sheet) on schedule.
