I am trying to make a family that I can use to put in specified lengths. This will be in a table and I would typically do this with text.
However, I have to enter the length in inches and I want Revit to convert the inches automatically to feet & inches.
I am trying with a label, however, I am not sure of a way to type in the label as the parameter is length.
I want the label to take an input such as 76" and feedback 6'-4".
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
That worked.
Is it possible to have an instance parameter that is "=Length", but outputs that in inches?
The values I am inputting are originally in inches, and need to be in feet/inches format, but it would be nice to have a way to verify they are the correct inches value as well.
Can the highlighted be inches:
@BigPicture045 wrote:
That worked.
Only if it is also a label so that you can Format Units to Inches.
What you are saying is that the instance properties panel will always output in feet & inches?
This would mean to see the inches it would have to be a visible label in the family correct?
Another way is not using Length for the Inches parameter, but using a Number parameter. Change the formula to: (Length / 1) * 12. Then you don't need to create a label.
