Generic Annotation EXPORT TO CAD not correct color
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
johnw
888 Aufrufe, 4 Antworten
In Revit Export I set ALL annotation categories and sub-categories to export as Color (6) Magenta. When I go into cad drawing, some text is showing as Color (7) White. I've triple checked and all my annotation categories are set to Color (6) Magenta. Also, the border around my text (text style has "show border" checked) should also be Magenta but is coming in as color 250. I am using ver 2020. See image attached as well. I hope someone has a solution to this problem. Thank you in advance.
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
syman2000
als Antwort auf: johnw
When you export, choose 2nd option from the list. This should export without those override.choose 2d.pngautocad.png
Nachricht 3 von 5
hmunsell
when exporting to CAD, some families are created to blocks. those blocks may be placed on the correct layer, but the content of the block is sometimes placed on layer "0". I usually only see this when i try to explode the block though.
Howard Munsell
Nachricht 4 von 5
johnw
als Antwort auf: syman2000
That worked! Thanks!
Nachricht 5 von 5
rbarbosa8DQGJ
Since annotation and other elements are families in Revit, you must choose a layer and finish layer export manualy in the autocad. Families are exported always in one layer. Families are converted to blocks, so, you may use command "setbylayer" in autocad, inside or outside blocks, to minimize manual redo... Also, follow the instructions to "not override". Will be more easy to treat lines and colors.
