Geforce vs Quadro
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
20075 Aufrufe, 14 Antworten
Geforce vs Quadro
Hello guys,
Would you please advice me which is better between Geforce Gtx 1070i vs Quadro P4000 or P5000 ? This Video card is going to use for architectural rendering & animation purposes (revit, cad, vray, lumion)
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: Anonymous
Better is relative. A Quadro is supposedly more stable but costs a lot of money. A GeForce of comparable or better performance cost way less. I personally have no stability issues with a GeForce GTX per se.
Nachricht 3 von 15
als Antwort auf: ToanDN
Ok thanks for your sharing opinion :leicht_lächelndes_Gesicht:
Nachricht 4 von 15
I did a comparison years ago between a GTX and Quadro and they were neck and neck for all the tests.  The Quadro was a bit better in 2D benchmarks but the GTX ran circles around the Quadro in 3D apps.
BTW, you mention Lumion.  Look at their suggestions...I believe they recommend GTX/Radeon cards over Quadro as well.
Nachricht 5 von 15
Thanks for your input, you got the point... so, i’ll get the gtx for both revit and lumion :leicht_lächelndes_Gesicht:
Nachricht 6 von 15
Viveka_CD
Hi @Anonymous
Depending on the version of Revit you will use - check this page for certified graphics cards
Nachricht 7 von 15
Simon_Weel
Most of uur Revit machines have either a Quadro K1200 or P1000. Fine for modeling work. We also use Enscape and a Oculus Rift for VR-experience. Then those Quadro's don't cut the mustard at all - way too slow. So we put a GeForce 1080 in one machine and now the VR-experience is as smooth as a baby's bottom..
Nachricht 8 von 15
johanwall
als Antwort auf: Simon_Weel
I'm in the process of evaluating if we need to buy a new laptop for our VR kit. The Quadro M2200 performance in our current machine is very poor. So comments from people with hands-on experience helps a lot, thanks @Simon_Weel! I will definitely recommend that we go for at least a GTX 1080.
J. Wall
Architect
www.johanwall.com
Nachricht 9 von 15
Tomislav.Golubovic
als Antwort auf: johanwall
I benchmarked my MSI with a Quadro P4200 against my Z800 with an RX580. The Revit Render was all pretty much done on the CPU, not the GPU
https://technexus.com.au/index.php/2019/01/20/benchmarking-my-pcs/
The Z800 being a 12-core Xeon, it faired better than the WS63.
Nachricht 10 von 15
dgorsman
Comparing a Kepler series or P1000 against a GTX 1080 isn't an even match.  You should seriously consider one of the newer RTX models for future proofing.  Just keep in mind a laptop will likely have some limits on what it can handle, and more hardware may not help that much.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Nachricht 11 von 15
amg.monaco
RTX has clear limitation if you run big project. quadro might suit for it.
Nachricht 12 von 15
Simon_Weel
als Antwort auf: amg.monaco
What limitations might that be? Our latest machines sport a GeForce RTX2080 and we do have some pretty large projects. No problem so far....
Nachricht 13 von 15
philippe_glouton
I currently run a pretty large project on LT version, it started to go slow when I decided to add some vegetations and trees (now the file is 174Mo). I run an RTX 2070 Max-Q my laptop, and I was wondering whether there was a way to improve the 3D view performances. I guess it'd be better with a Quadro card, but of course, I use Twinmotion for rendering :')
Is there any way to get smoother browsing in 3D view with an RTX? When you exceed a certain file weight, because it runs flawlessly in other (smaller) models
Nachricht 14 von 15
pierce_cheung
als Antwort auf: philippe_glouton
I personally think RTX 2070 is good enough for 3D works, what’s the RAM capacity of your PC, Sometimes when there is not sufficient RAM, it slows. Also the storage socket type matters if you have large file to read and wright regularly between the RAM and the storage
Nachricht 15 von 15
EATREVITPOOPCAD
So at work I have an Nvidia RTX A5000 (I think costs close to $3000) which is a bit expensive and at home, I have a 2015 Nvidia Geforce Titan X Pascal which I bought used for $500 and I'll be honest... I am impressed with the Titan X  and I think I will be using for a long time. So kind of like with cars, if you have a budget for a brand new Hyundai or a used Lexus, the used Lexus may be a better choice for you, I would look into premium used premium cards. At least it worked for me, just be careful not to get ones that been heavily used to mine cryptocurrencies :sich_vor_Lachen_auf_dem_Boden_winden:
The definition of insanity is doing the same thing over and over again and expecting different results
