gbXML import error in ecotect 2011
1 ANTWORT 1
Nachricht 1 von 2
666 Aufrufe, 1 Antwort
Hii all,
I am facing a problem in importing gbXML file to ecotect. I exported my model from the designbuilder in gbxml file format but when i tried opening in ecotect it is showing below error.
"WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
Please help me to solve this problem.
Thank you in advance,
Abhi
1 ANTWORT 1
Nachricht 2 von 2
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
  • This error is being presented because the gbXML export file is not encoded in a format Ecotect recognizes (and for some reason triggers an IFC error message).
  • Unlike earlier versions, Revit 2013 exports in UTF-16 format whereas Ecotect expects UTF-8.
  • The simplest way to work around this is to open the gbXML file in Windows Notepad and save the file, ensuring you change the encoding format to UTF-8.
  • Check post below:
    http://autodesk.typepad.com/bimtoolbox/2012/08/revit-2013-gbxml-not-importing-into-ecotect-2011.html
