Gather and Package Textures from Revit file
2 ANTWORTEN 2
Nachricht 1 von 3
906 Aufrufe, 2 Antworten
I was surprised to find out that material texture images are not gathered up by the E-transmit process. Instead, they must be "manually copied".
This is a bit ridiculous, since it would involve making a list of used materials and then going to hunt for them manually. Even if your firm has a proper material library, this is an inefficient and error-prone workflow/endeavor.
Is there an ideal way to automatically gather all used material texture files? I did add an idea to fix the E-transmit function.
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
ryan.duell
als Antwort auf: Anonymous
Thank you for adding the Revit idea for that topic.  Currently only Decal image files are supported with eTransmit as you mentioned.
Ryan Duell
Nachricht 3 von 3
als Antwort auf: ryan.duell
Thanks @ryan.duell,
I'm hoping that one day the E-transmit from Revits works as flawlessly as the AutoCAD E-transmit. It's a bit hard to explain to my coworkers that there's not really a solution that can properly archive Revit project files. It's even harder to explain how they would go about doing it all manually! Frustrierte SmileySmiley (überglücklich)
