Gaps between applied walls
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
358 Aufrufe, 1 Antwort
Hi everyone
I imported an object from fusion 360 into Revit, when I applied wall by face some walls did not join together, I tried to join them or re do them but it did not work
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
The problem is that the walls meeting at the seam are is 90 degrees to the plane.  Almost impossible to correct.  If you use a roof with a plumb cut you might get a more acceptable condition -- or at least eliminate the gap between.  But then you have an overlap instead of a gap.
Can't you edit the Fusion element?
