Gap between landing and staircase after finish sketch
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
aznil_zuhil
403 Aufrufe, 4 Antworten
Hi, i am new doing staircase. I want to know why my landing does not follow as my sketch. Seems like it has offset when i finished my sketch and have some gap to the last riser. Attached image for reference, thank you
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
MachielAEC
als Antwort auf: aznil_zuhil
This possible looks like you might have used the Pre-Cast Stairs where you have a 'gap' that can be controlled in the distance.
Can you share a section and/ or the staircase in a separate project?
Machiel Odendaal
---BIM Enthusiast---
Nachricht 3 von 5
aznil_zuhil
Yes its a precast. In 3D & Section there is gap. but in plan looks okay. However, i managed to edit sketch for the landing and i can remove the gap. Although there are warning says it will be unjoin after finish sketch but looks no issue. Am I doing the right way?
Nachricht 4 von 5
Have you checked these properties?
Zero out the Gap distance.
Nachricht 5 von 5
aznil_zuhil
als Antwort auf: barthbradley
Awesome. Yeah mine is 10mm gap, no wonder. Thank you so much!
