Hello Everynone
I am trying to make stairs with tread and riser material of 50mm.
While i do that and also extend below riser base, there is a gap created between the floor and the riser due to the thickness of the riser material. See the attached images. Can anyone provide a solution for this ?
Thank you !
Add a floor slab edge to fill the gap. You can stretch the slab edge to be the same width as the stair.
