FURNITURE LINES DISPLAYING OVER WALL LINES
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
s_bataller
396 Aufrufe, 4 Antworten
I have a problem in every single project. When i place furniture close to walls, the family lines display over the wall lines making the floor plan look weird.
Is any possible solution to that? On the image below you can see the problem, the furniture is like cutting the wall line
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: s_bataller
Select Detail Element in Plan View of Family and Uncheck Draw in Foreground.
Nachricht 3 von 5
s_bataller
als Antwort auf: barthbradley
but this will make the family like transparent right?
Nachricht 4 von 5
s_bataller
Nevermind it worked! I just hided all the 3d elements and worked with detail elements in a lower reference plane, so the wall gets prio
Nachricht 5 von 5
finley97544d
When working on architectural drawings or interior design plans, it's common to encounter furniture lines displaying over wall lines, which can cause confusion and disrupt the clarity of the layout. This issue often arises when layering is not properly managed, leading to overlapping lines that obscure important structural details. To maintain a clear and professional drawing, it's essential to adjust the layer order, ensuring that wall lines remain visible and prominent while canada furniture elements are subtly positioned beneath them.
