I need to import some models from SketchUp to Revit . Is there a way to do it ?
How is the workaround? Anyone can give me a hint
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
…. hi @Anonymous
…. It is a tedious and relatively boring and annoying process
… but if needed
… here is a “workaround”
…. go here import to revit and follow the steps
… and then apply materials following here apply materials
… and then render it in REVIT
... I 've just applied random materials
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Thanks @aRcHiTeCt.JM . I will be trying it. I will let you know. That sounds perfect.
Thank you again. Works perfectly. Take a look at the sculpture sample. I went to the Sketchup Warehouse and downloaded a sculpture. I followed the entire process and take a look at the super cool render result in Revit.
@Anonymous wrote:@Anonymous Do you mind sharing the Sculpture file ? Please. Thank you.
@Anonymous Not al all. Here is the file and the material that you have to apply in order to get the result. Follow instructions in the first post from @aRcHiTeCt.JM
Go to Store and download "ImportSKP" (for AutoCAD). Open AutoCAD and use ImportSKP to bring in the SKP and save the DWG. Insert DWG into Revit. Done.
Thanks @barthbradley Do You mean This one
It is not working for me because I only have 2020 Version and this is up to 2019.
Nevertheless it a longer process than the First posted here. It will be three steps VS. two steps. And I don't use Autocad. Just Revit and Sketchup. Thankyou for the intention but did you take a look at the rendering that I made importing directly from Sketchup. It is so cool and simple. I have even transform so far like 10 families and now the process of doing it is super simple.
It is definitely available for 2020 AutoCAD. I'm looking at it right now.
Keep it in mind. You might need to use it in the future. And you really don't need AutoCAD experience to do it either. It's dumb-proof. I promise.
